05_Kangaroo planarize.gh (12.4 KB)
I am trying to have a planar elements on the curve surface, Can anyone tell where I am going wrong.
I am having the same problem. Did you solve it by any chance?
It is probably simply not possible, as constraints of anchors contradicting with planarization weights.
If you remove anchors, you will see how much surface has to vary to be planarized.
I think you’ll do better using a more recent Kangaroo release. You’re using 0.099, which is much less stable. That said, planarization isn’t really a trivial problem, and your initial geometry and form are going to have quite an influence on your outcomes.
