Join mesh from and outside rhino
Hi
I am trying to join a sweep made in grasshopper based on the curve of a mesh from another program, The edge seems to match but I can’t seem to make it into one mesh. Which method should I use to make the dress and the shoulder cone into one mesh?
shoulder pads.gh (154.3 KB)
Flatten the input to Join Mesh.
Thank you! This works!
Hi, Just one more issue regarding this, after I have joined them the mesh seems to still have creases and not be perfectly joined, working both with triremesh and quadremesh, is there a way to improve the connection between the meshes and make it more smooth?
shoulder pads 2.gh (157.1 KB)
I seem to have eliminated the naked edges but it required using a couple of plugins. One possible source of the problem was trying to create a surface between a polyline and a circle and then meshing the result. I used the Align Curves Seams component from Pufferfish and the Mesh Loft component from Mesh+.
shoulder pads 2b.gh (165.2 KB)
Thanks again! This is amazing!
