to introduce some random translation / scaling / rotation to certain objects or blocks, mostly to make it look more natural.
Unfortunately the scrip is not working anymore in R7, so I wonder if anyone out there might have a easy to use alternative. I am sure it might be a rather easy thing to do in Grasshopper but it is ,so I learned in the last 2 hours, over my abilities.
Have you tried the good old QuantumTransform plugin by David Rutten?
It’s quite ancient but still works brilliantly for such needs.
I am not sure why it is gone from David’s Rhino Wiki Page, but here it is: QuantumTransform.rhp (48 KB)
Once you install, see the commands starting with Quantum… it’s pretty self-explanatory, you can either eyeball the values by mouse or limit tranforms scopes numerically.
