Rotate blocks randomly around their basepoints
…Is there a way to do this? I am trying this for 2 hours now, but I have no success…
any help would be really appreciated .
thank you for any feedback
Andreas
Initially I was thinking of a plugin I used a liitle while ago: http://www.food4rhino.com/app/rhinogrow but then I reaslied you don’t want them to move?
Andy
Hi Andreas - you’ll need a script for this - here’s a quick Python, in case that helps -
import rhinoscriptsyntax as rs import random
def test():
Ids = rs.GetObjects("Select block instances to rotate", filter = 4096, preselect=True)
if Ids is None: return
vec = rs.VectorCreate([0,0,1], [0,0,0])
for Id in Ids:
    pt = rs.BlockInstanceInsertPoint(Id)
    ang = random.randrange(-180, 180)
    rs.RotateObject(Id, pt,ang,vec)
if __name__ == "__main__": test()
I still use the Harmony script to randomly rotate objects: http://www.rayflectar.com/p04-Programming/programming.html
(Jitter option) though I can’t recall if it worked with blocks or cared about their basepoints.
first of all thanks for the swift feedback - cool community!
@pascal : thanks for your effort, it is really appreciated, I tried to use your script, I copied the text between the dot line and pasted it in the python editor, but something is not working here … what am I doing wrong?
here is a screenshot:
@2DCube, @edhenry70 : thanks for your suggestion, I know and use both tools , but the problem here is that I would like to be able to define a point around the rotation would take place…
maybe it is a good idea to explain what I would like to archive…
I have a leave (block), which is attached to a small branch, I also have a 3D curve. I would like to distribute numerous copies of this leave flowing along that curve with a random degree of rotation.
It should look like a kind of Ivy / liane…
I already considered buying the armadillo plugin, but I shy away from the pricetag
any Ideas?
best
Andreas
You need to indent the whole script under def test(): - the formatting on Pascal’s post went wrong, should look like this:
import random
def test():
    for Id in Ids:
    test()
–Mitch
thanks Mitch → now it works !
Ah I get you. Maybe @Jarek can help with ArrayCrvPLUS?
I use if for a lot of things, it should do what you need here - there’s a lot of functionality with regard to rotation, scaling etc.
Andy
yes, I remember I used to use it in the past, however I cannot find it anymore… do you have an old version or a working download link?
thanks
Andreas
Hi Andreas,
you can get it from here: http://www.dig.gallery/misc
–jarek
