Issues with Anchors in Kangaroo
I am having issues with anchor points in Kangaroo, despite mapping them into the mesh vertices.
The results look like this:
I think its related to how i build the meshes, but I am not sure how to fix it.
Any ideas?
The file with internalized geometry:
Tensile square2.gh (20.5 KB)
Hi @Elena_Vazquez_Peña
The main problem is that your two meshes have edges that have don’t align with each other. Quadremesh also has a hard time retaining exact features of input shapes as you can see in the bottom left corner. I assume it’s because this is a topologically difficult problem to solve.
I believe Kangaroo does with weird thing where if two vertices share the same coordinates they sort of fuse together and are treated like one shared vertex even if they’re on different meshes and or different branches. Kangaroo is exceptionally unruly in my experience.
One way to make sure the edges align nicely is to mesh the surfaces based on their U and V directions, which gives you control over the subdivisions in each dimension. This requires the input surfaces to have clean U and V directions. This won’t work with the geometry you got from Split Surface because they come out as Trimmed Surfaces that share the same U,V directions as the input rectangle.
Tensile square2_NL.gh (23.8 KB)
Tensile square2_NEG.gh (22.3 KB)
Is this suits you?
So simple and effective! Thanks!!!
