Issues trimming a mesh?
Hello everyone,
So I am trying to trim a mesh using Mesh Trim, Mesh Split, but it just doesn’t seem to work with a curve. I first had two surfaces I joined using mesh, and now I want to trim it using this curve I draw on the surface before I converted it into a mesh (using InterpCrvOnSrf), but it just doesn’t work. Ideas on how can I do it? (I attach 2 pictures: the first one of the mesh with the curve on it; the second one, of a surface that is exactly how the mesh should look like)
Thanks in advance!
Hi Fiorella -
What does this mean exactly? What commands, exactly, are you using? Can you post the surfaces and/or meshes and curves here in a 3dm file?
thanks,
Hi Paola,
if the trim/split doesn’t work it’s because the intersection isn’t complete.
Check your curve to be closed.
Check also to not have the cutting curve perfectly tangent to the surf edge.
Se hai problemi qui trovi il discourse in italiano: http://it.discourse.mcneel.com/
Ciao
