Issues scaling angular dimensions
Hi there,
I am having some trouble scaling angular dimensions. I made a python script where I read a DXF file created by another software that only outputs in millimeters, then does some drafting tasks (layer changes, texts, dimension styles, etc.) and then scales to inches before exporting into a new DXF file.
It all works fine except I cannot get the angular dimensions to scale properly, they are always too big.
What can I do to get these to scale correctly like the rest of the dimensions do?
Here’s an example.
Before scaling:
After scaling:
Thank you!
I noticed this was changed to scripting but just wanted to mention that it also happens when scaling manually in Rhino.
Hi Manuel -
Manually, you’d have to modify the dimensions one-by-one by selecting the middle control points and moving those.
2025-11-07 - EditAngularDim
Thank you Wim!
I need to do this on hundreds of drawings (hence the python script). I hope there is a way to do it via script.
