Hello everyone,
I am currently trying to create a variable thickness slab using SOFiSTiK software, but I believe there might be a bug in the plugin. I’ve double-checked my inputs, and everything appears to be correct.
When processing the information through the SOFiSTiK plugin, the output consistently applies the same thickness values to the slab edges, which isn’t what I intended.
For example:
I isolated 4 elements:
The result is:
As you can see the values in tree 0;0 are being replicated
Am I doing something wrong, or is this a known issue? If it is a bug, does anyone know if it has been addressed in newer versions of the software?
Thank you in advance for your help!
Test_Variable thickness.gh (264.7 KB)
