Region Slits
Hello, GH community,
I have a main sheet and five small sheets. The thickness of the main sheet is 3 cm, and the small ones are 2 cm. I’m trying to use the Region Slits component, but it does not have the option to use different widths for slits. Is there any way around to manage this in GH without using manual processing?
Please, see the file attached.
RegSlits.gh (5.9 KB)
RegSlits CUT AGAIN V0.gh (17.5 KB)
There is a Region Slit component that can adjust the individual width in the Nautilus plugin.
But if you don’t like to pay, just follow my gh.
Hello, Quan Li,
The solution is very helpful.
Thank You :pray: :pray: :pray:
hi @Quan_Li
i have same problem. and i tried your algorithm on my project but did not work and also i think there is some bugs i mean it causes some broken panels. is it possible for you to take a look at my algorithm? many thanks
AAAw.gh (36.1 KB)
Related.
RSlits(Topology) returns nulls - Grasshopper - McNeel Forum
