Issue with tween between two curves along guide curves
I´m a beginner and just started out learning grasshopper. Currently I am trying to rebuild geometry that I built with classic Rhino operations previously -
I am stuck at a in my eyes rather simple task - I´ve searched through forums, youtube tutorials and all sorts without luck, so I thought I post my issue here.
I want to tween two curves along guide curves, one straight, one curved. The tween results in tilted curves instead of being parallel to my z axis.
I found a way to divide the curved guide curve, but somehow can´t fix my tween.
Did that happen to someone else before and is there a solution to this?
thanks so much in advance,
Kim
Post your code. Check your curve directions - might need to flip them. But post your code.
Ahh, of course! Here are the rhino and gh files, also showing the geometry that I am after!
tween issue_GH file.gh (10.6 KB)
tween issue_posted on forum.3dm (8.6 MB)
Opened your file, R8:
This looks wrong?
Hi René,
Correct - that’s wrong :smiley:
I would like my tween to move in between the constraint curves in the model, but somehow can’t manage.
Maybe tween isn’t the right command for this - and very possible there’s a better way to achieve this?
Got it.
Maybe this is a temporary workaround:
tween issue_GH file.gh (16.0 KB)
Or these:
tween issue_GH fileb.gh (15.6 KB)
tween issue_GH filec.gh (16.6 KB)
Hi René,
amazing, thank you!! Great to see that different paths lead to the result - thanks for your time and input! in my brain file c makes most sense :sweat_smile:
