Issue with Imported DWG/PDF Lines Appearing Extremely Thick in Rhino 8
I am experiencing a consistent issue when importing DWG or PDF files into Rhino 8. After import, the curves appear extremely thick on the screen, to the point that the entire viewport looks filled with colors, while the control points remain normal and properly scaled.
I have tried the following without success:
  1. Disabling Line Width and Show Line Widths in Pixels in the Display Modes.
  2. Resetting all Display Modes to defaults multiple times.
  3. Setting Print Width to Hairline for all imported objects.
  4. Importing PDFs with line widths set to minimal values both in Adobe Illustrator (0.25 pt) and Autocad, using “Import Line Widths” both enabled and disabled.
  5. Using different viewport modes (Wireframe, Shaded, Technical) with different viewport settings.
The problem persists regardless of file type (DWG, PDF, DXF) or scaling, which suggests that the issue is internal to Rhino’s interpretation of imported 2D curves, possibly related to Curve Thickness or viewport rendering of imported curves. Even after resetting Display Modes and turning off all line width options, curves continue to display as excessively thick.
This issue prevents proper visualization and manipulation of imported 2D geometry, especially when working with architectural plans or technical drawings.
Could you please advise whether this is a known issue in Rhino 8, and suggest a solution or workaround for properly importing curves without automatic exaggeration of thickness?
Hi Tomas -
Please post both the output from the Rhino SystemInfo command and a DWG or PDF file that illustrates this issue.
Rhino 8 SR21 2025-7-7 (Rhino 8, 8.21.25188.17001, Git hash:master @ 2e05bb7e11ec03aa58cc543d92330d59df05d32b)
License type: Educational, build 2025-07-07
License details: Stand-Alone
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 8.0.14
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro K2000 (NVidia) Memory: 2GB, Driver date: 7-22-2015 (M-D-Y). OpenGL Ver: 4.5.0 NVIDIA 353.62
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 4.5 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50 NVIDIA
Driver Date: 7-22-2015
Driver Version: 10.18.13.5362
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.21.25188.17001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rendering di Rhino” 8.21.25188.17001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.21.25188.17001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.21.25188.17001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.21.25188.17001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.21.25188.17001
2 GB is only half the absolute minimum required for Rhino 8. The video driver is 10 years old. If you want to run Rhino 8 on this desktop I think you’ll need to update your video card (and driver).
Frankly I’m surprised that you can accomplish as much with your setup as you apparently are.
Thank you for your kind reply.
