Import files problem in Rhino 8
Hello.
I have a quick question as the title.
When I import the cad or any file to Rhino 8, all the line or surface too bold in all view as image below.
image.pdf (191.1 KB)
I use draw line or surface in rhino 8, there is no problem.
Only import any file to Rhino 8, It happens.
I can’t do any work right now…
Do you guys have any idea of this?
I tried to restore defaults in view or any rhino options, but It never changed.
Hello @조혜정
Could you send a sample file you try to import? Most likely there is a line width setting that needs to be addressed.
Also, pls run _SystemInfo in Rhino and post back the results
