Issue while nesting multiple crv
I didn’t do it earlier because the contours were already recognized as closed curves, but now I think about it probably it’s better practice to pass Brep Edges through a Join Curve, in such a way to get all closed contours (if they are already closed curves, then Join Curves won’t harm)
Multiple nested curve types inside one sheet examples 2_Re.gh (20.3 KB)
the role of Boundary Surface is indeed just to facilitate the creation of a data tree of Curves when used in conjunction with Brep Edges
Nice one! I encounter an overlapping of shapes when i try to scale up this. Last two curves are essentialy same shapes but smaller. Not sure is this about Open Nest or what.
Multiple nested curve types inside one sheet examples 3.gh (23.5 KB)
the black thick outlines that look like intersecting each other are just to highlight the simplified shapes used for nesting (you can make them more precise by increasing the Simplify value, now set to 20)
real nesting contours are the ones you visualize in light blue, parts are just nested inside each other :+1:
