Issue Meshing Imported Parabolic Dome for Karamba3D Analysis
I am working on a parabolic dome structure and need to perform structural analysis in Karamba3D.
I started from a reference model in AutoCAD, then imported it into Rhino. In Grasshopper, I referenced the geometry using “Set Multiple Curves,” assigning each curve individually to define the grid in both X and Y directions.
The issue is that I cannot generate a proper mesh for the dome. or any mesh at all.
Since the original model applies loads on a mesh, I need to replicate the same approach to obtain comparable results in Karamba3D.
Could you advise on the correct workflow to convert these curves into a mesh suitable for structural analysis?
Thank you.
Below view of the auto cad and grasshopper script/rhino model
you can generate a mesh from curves using weaverbird for example, or you can create a delauney mesh from a list of points too.
