Generate a mesh from projected lines from pull curve in a parabolic dome
I created a parabolic grid shell dome surface using revolve curve and then use planer surface that I divided it using isotrim and projected these surfaces in my dome using pull curve component then I extract the end point of these curve and connected the points using line component (to be lateral defined as structural beams)
the problem is that I want to create mesh between these square lines for structural analysis lateral ..
any advise
part of my code and generated shape picture are below.
update I tried wave birds mesh from line but also I had the edge not meshed even though the arch were transformed to lines
I solved this in your previous thread :confused:
Thank you a lot I found it just now
