Issue importing into revit
When importing the attached file into revit the model divides into two elements one with the correct scale and the other way out of scale. I will attach an image of how the model looks when imported into revit, idk if there is something wrong with my model or the way I import it into revit.
Rhino file:
Your Rhino file has no units system specified.
I arbitrarily set it to millimeters with a tolerance of 0.1 and it appears to import all at the same scale.
