For some reason, elements will not transfer from Rhino to Revit in one particular document.
If I try it in another document and then copy and paste them to the desired document, they are fine…Is there some sort of setting in the document in question is should change?
I know this is might be a difficult one to try and troubleshoot, so thankyou for any help!
More often than not transfer will be tripped up by tolerance, or a model being a long way from 0,0,0. Is one model a site model that has a site way out on civil coordinates space?
Units can also make a difference. Is the unit system different from one file to another?
Phases in both files are the same, that issue had already caught me out on this particular project! Haha.
Both models are quite close to 0,0,0, and the tolerance in the rhino document is set to 0.1mm and 0.1 degrees.
I am trying to import these elements as a new component family.
As I said, it all works if I try and import them to a new file, but something is not working with this file specifically… I have uploaded a copy of the Grasshopper and Revit files, I cant send the rhino as its too big… REVIT TRANSFER TEST_R22.rvt (13.8 MB) Transfer to Revit.gh (11.4 KB)
