Hello all
Is there a specify option to orient isocurves on surface ?
Thanks in advance
Dan
Hi Dan - in general, no there is not - these are a reflection of the UV structure of the surface, not arbitrary - in specific cases like a trimmed plane, you can do something like DupBorder then UntrimAll, rotate the resulting untrimmed plane to taste and then trim with the curves from DupBorder. But why…?
Hello Pascal
Thank you for replay.
I had a ‘‘vision’’ how I can create something by using isocurves, but it seems that won’t work.
I found other way how to do it.
Many thanks
Dan
