Is there an fbx export option in Rhino similar to "Embed Media" in Maya?
Hi everyone,
I’m currently doing research with some architects at Virginia Tech and I need to export a building model from Rhino into Unity 3d. The model works fine, however the textures don’t seem to transfer over. Based on some initial research it appears other software such as Maya has an FBX format option to embed the media into the fbx and it imports fairly well into unity.
I’m wondering if there is a similar option in Rhino or if I should export to a different file format to achieve a similar effect.
Thanks
Yes, some of Rhino’s export file formats can do that. The most common one I hear about is OBJ. I don’t know if FBX will do that or not.
