Is there a way to make the orientation frame for a plane smaller?
In my grasshopper window, whenever I make a plan and the orientation frame (this thing) appears, it’s always so much bigger than my working geometry, I’m unable to see what I’m doing clearly.
Is that orientation grid at a fixed size? I’m usually working in the ‘small objects - inches’ template, so I thought maybe if I worked in the ‘feet’ template, it would appear smaller.
Hi @TheCyclist,
You can change plane display size here:
Lina,
Thank you! That solution is so simple.
sure is, when you know it :wink:
