In Grasshopper i can use the trick of doubling the values and then adding an expression in the slider, x/0.5 to get what i want. But it seems the expressions in the slides don’t work the same way in Shapediver, as the expression result isn’t displayed, but rather the input value.
i also tried to add snapping values on the slider, but doesn’t do the trick.
We don’t support expressions applied to sliders at the moment, because they would need a deep change in the parameter logic in the viewer. It is in our roadmap though and I will update the topic when we release the update.
