Slider with Incremental Value
Hi
I’m trying to create a slider with an incremental value that will drive a model in shapediver.
Starting at 60cm and going up in increments of 20cm to 300cm.
I feel like it should be simple, but I’m new to Grasshopper and for some reason it’s beaten me.
Hope you can help
Oh wow! That works perfectly. Thanks Joseph
for some reason the expression works in Grasshopper but it doesn’t carry through to Shapediver.
slider snapping isn’t carrying through either
How about putting the same expression in an Evaluate component? (‘Math | Script | Evaluate’)
incremental_slider_2021_Jul14b
incremental_slider_2021_Jul14b.gh (3.5 KB)
Or does Shapediver support the slider ‘Edit Snapping’ feature? (right-click slider, ‘Edit Snapping…’)
incremental_slider_2021_Jul14c
incremental_slider_2021_Jul14c.gh (2.3 KB)
Bummer dude!
Yeah it is a bit. I’ll reach out to shapediver and see what they say.
Thanks again
This is ridiculous, of course, and the slider values range from 0 to 1.
incremental_slider_2021_Jul14d
incremental_slider_2021_Jul14d.gh (9.0 KB)
There is no support for expressions on shapediver. The snapping feature looks promising for doing what you want, and I just added it to our backlog, but at the moment the only way to snap sliders to specific values is through the Javascript API.
Thanks for getting in touch Mathieu.
I’ll use the slider and show dimensions in the model space. Or I’ll use value list.
let me know when the snaps are added to Shapediver.
Hi @mathieu1 can you tell me if this snapping feature has already been added to shapediver?
We found out that snap ranges are not exposed to the Grasshopper SDK, therefore there is no way to support them at the moment.
As incremental sliders (with expression) now work, is there a workaround to have the slider display the calculated values?
E.g. Slider from 100 to 200 in increments of 5 appears as slider from 20 to 40 in ShapeDiver but the actual value used is 5X.
Thank you!
Dragos
At the moment, this is not possible, but we are evaluating ways to support this in the App Builder. I will update this topic once we make progress.
