Is there a ball bearing roll along user defined edges fillet command?
V8 still fails on filleting.
If it took a ball bearing and rolled it around the user selected chained edges then this wouldnt happen.
V5 fillet edges does my head in, V8 I had hoped was better.
ball bearing fillet option wanted.3dm (2.7 MB)
Steve
The fillet option exists and is called rolling ball. However in your case the fillet fails because of the narrow circle segments. You can trim the surface with a pipe and use the BlendSrf command
trim with pipe and blend.3dm (1.3 MB)
Duplicate topic. Please merge.
When fillet fails the pipe trim trick prevails :smiling_face_with_sunglasses:
