Is Penguin 2.0 compatible with Rhino 7?
Hi, anyone knows if the latest version of penguin plugin is compatible with Rhino 7?
Hi, the latest version of penguin you can find in the rhino3d web page (Rhino - Download - Penguin 2 for Windows) can be loaded and used in Rhino 7.
The installer you can download from that page will install it on Rhino 7 as well as previous Rhino versions.
Regards,
Adan Guillen
This no longer works. Says Rh5 must be installed first - really?
Hi Nicolas -
I’m not getting such message when I try that here on a machine that doesn’t have Rhino 5 installed.
Since this might be a licensing issue, please contact sales@mcneel.com to have that looked at.
Many thanks – will do!
Nick
Nicolas G. Loebel, Ph.D.
President & CTO
ONDINE RESEARCH LABORATORIES INC.
19017 120TH Ave NE | Suite 102 | Bothell, WA 98011
nloebel@ondinebio.com | www.ondinebio.com
Tel: 1.425.489.1100 | Fax: 1.425.489.1101
Interesting. On a work machine, same license, it DOES install. Something stuck in a cache somewhere on the other machine perhaps.
Thanks again for this input.
Nick
Do you need both Rhino 5 and Rhino 7 installed on the machine?
