Hi Erveryone,
I must admit I only know very little about coding, but I want to know if it’s possible to use any of the samples on rhino docs in the C# component:
As an example I would love to use this script in gh:
Thank you,
Thomas
Hi Erveryone,
Thank you,
Thomas
private void RunScript(Mesh mesh, List<Point3d> points, Vector3d vector, ref object A)
int[] indices;
var prj_points = Intersection.ProjectPointsToMeshesEx(new[] {mesh}, points, vector, 0, out indices);
A = prj_points;
ProjectPointsToMesh.gh (9.7 KB)
Hi Mahdiyar,
Thank you so much. This is great!
…eventhough I still don’t get how you did it
But I guess I should look into C# coding or ?
Cheers,
Thomas
Dear @toh
the developer samples you quote are for plug-in development. As Plug-ins target to be rhino-commands and not grasshopper components the sections of the script that handle the input and output are different.
But
the section that handles the geometry is the same for a rhino-c#-plug-in-command and a Grasshopper component.
for the example you mentioned:
var prj_points = Intersection.ProjectPointsToMeshesEx(new[] {mesh}, points, new Vector3d(0, 1, 0), 0, out indices);
of course can be used inside a grasshopper c# script or grasshopper component.
you may also want to check out
https://developer.rhino3d.com/api/grasshopper/html/730f0792-7bfb-4310-a416-239e8c315645.htm
kind regards -tom
Hi @Tom_
Great thank you so much. This makes sense I think
But is it possible to find a “library/overview” of all the variables that I can use in a C# script / component?
I’m gonna check out your link,
Kind regards
Thomas
thats your starting-point:
https://developer.rhino3d.com/api/RhinoCommon/html/R_Project_RhinoCommon.htm
Uhhh biig library
- amazing!
