I was wondering if it was possible to create a custom projection mode by editing “Projection Vectors”
For example, the ‘top’ view port mode arranges the vectors this way:
Another example in perspective could look like this
What I would like to achieve is an ‘Axonometric’ view mode configured as follows
is this possible to achieve? thank you.
you can achieve something that looks exactly the same, but you would have to change a few things, but if this is for some special styled representation only it is better than nothing for now.
first start with the command Isometric, then go to your display mode and change the vertical view scaling to 1.75. now you have the angles pretty much correct i believe. you can save this as an extra display mode. comparing it to your example if that is accurate you still have to scale the object/s with the gumbal along z and enter 0.7 in the leaver.
Thank you! if you don’t mind me asking, where can i change the view scale, I cant seem to find it?
