We’re developing a python framework which can be used via RhinoPython/Grasshopper. Occasionally, while testing new developments, Rhino abruptly crashes running the code. Working around these issues is mostly based on guesswork since the IronPython stack trace from running the code is lost.
Is said stack trace saved anywhere in the event of a crash? Is there anyway to get Rhino to save it?
Creating a contrived minimal example which would reproduce the issue often proves tricky due to inheritance trees and general complexity of the framework.
Additionally, I am not seeing any crash dump being created on the Desktop after the crash, is it possible that it is created somewhere else?
Below are the SystemInfo extract and the Windows EventViewer entry:
Thanks!
Chen
Rhino 7 SR20 2022-7-12 (Rhino 7, 7.20.22193.09001, Git hash:master @ 9b19bfdb8c343dd6fa8df3514068defd72273d6f)
License type: Educational Lab License, build 2022-07-12
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Unplugged [72% battery remaining] ~344 minutes left
Primary display and OpenGL: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 5-31-2022 (M-D-Y). OpenGL Ver: 4.6.0 - Build 31.0.101.1999
- Secondary monitor is laptop's integrated screen or built-in port
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 31.0.101.1999
Driver Date: 5-31-2022
Driver Version: 31.0.101.1999
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp "Commands" 7.20.22193.9001
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 7.20.22193.9001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 7.20.22193.9001
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp "RhinoCycles" 7.20.22193.9001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp "Grasshopper" 7.20.22193.9001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 7.20.22193.9001
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp "Displacement"
EventViewer entry: (faulting module seems to vary for the same instance of the error [sometimes ntdll.dll])
Faulting application name: Rhino.exe, version: 7.20.22193.9001, time stamp: 0x62cd9e22
Faulting module name: clr.dll, version: 4.8.4510.0, time stamp: 0x62461f56
Exception code: 0xc00000fd
Fault offset: 0x0000000000005303
Faulting process id: 0xae8
Faulting application start time: 0x01d8ae555e00c023
Faulting application path: C:\Program Files\Rhino 7\System\Rhino.exe
Faulting module path: C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll
Report Id: 7ca84980-d2d9-41e0-82a8-cb3da06e1b26
Faulting package full name:
Faulting package-relative application ID:
