iRhino3D WIP is now available via Testflight
Testflight is what we use to provide WIP versions of iRhino with new features that are being worked on before they are introduced into the official iRhino app.
iRhino3D WIP (8.0.22347 - Dec 13) is now available via Testflight
Summary:
New version of iRhino3D WIP introduces Room Scan feature which allows you to create a 3D model of an interior space using LiDAR sensor of your iPhone or iPad. You can also save the result in a 3DM file. This version also fixes a couple of bugs seen of older devices.
Bugs Fixed:
  • USDZ import: Fixed transform of objects imported (RV-661)
  • Radio sample crash due to OpenGL code (RV-676)
  • Startup in non-english language crash fixed.
  • Fixed 4view viewport arrangement (RV-663)
  • Fixed curve display issue.
Enhancements:
  • UI: Re-organize settings panel
  • UI: Detect if LiDAR sensor is available on device (RV-679)
Features Added:
  • File Save: Added feature to allow saving of 3dm files.
  • Room Scan: Using Apple’s Roomplan to generate 3D model of interior space.
iRhino3D WIP (8.0.23001 - Jan 3) is now available via Testflight
Bugs Fixed:
  • EXR related crash (RV-706)
  • Draw CurveSet Crash (RV-703)
  • Black camera feed in AR mode (RV-700)
  • Switch view in 2view mode (RV-692)
Enhancements:
  • Room Scan result to open in shaded mode (RV-709)
  • Texture support rendered mode (RV-712)
Features Added:
  • Selected Objects Properties panel (RV-695)
  • Save to Rhino 8 or 7 format (RV-699)
  • Change layer color (RV-694)
iRhino3D WIP ( 8.0.23039 - Feb 12) is now available via Testflight
Bugs Fixed:
  • Dismiss Radio sample dialog (RV-720)
  • Crash USDZ mesh attributes (RV-723)
Enhancements:
  • Toggle grid axes visibility (RV-726)
  • Align scanned room to X/Y axes (RV-719)
  • Change layer color swatch appearance (RV-711)
  • Layer visibility in model space (RV-710)
Features Added:
  • Add dimensions to scanned room (RV-731)
  • Import files (RV-727)
iRhino3D WIP ( 8.0.23047 - Feb 17) is now available via Testflight
Bugs Fixed:
  • IsoCurve and edge thickness slider bug in display settings (RV-741)
  • StatusBarProgressMeterStart Crash (RV-740)
iRhino3D WIP ( 8.0.23058 - Feb 28) is now available via Testflight
Bugs Fixed:
  • RDK related crash
Enhancements:
  • Improved AR Anchoring (RV-746)
Features Added:
  • Fine-tune scene position and orientation in AR mode ( RV-747)
  • Ability to change model units ( RV-743)
  • Object selection menus ( RV-745)
iRhino3D WIP (8.0.23074 - Mar 16) is now available via Testflight
Bugs Fixed:
  • Null check bug fix
Enhancements:
  • NURBS output for scanned room RV-754
  • More accessible AR mode menu
  • Selection menu behavior RV-745
Features Added:
  • CPlane toggle for AR object placement
  • AR anchor mode, image tracking RV-756
  • AR anchor mode, face tracking RV-755
We’re trying something new with Testflight builds of iRhino3D
Moving forward, WIP releases of iRhino3D via Testflight contain some features that are not completely finished. These features have known and unknown limitations and may make iRhino3D WIP less stable, but in the spirit of being open about our development I think it’s important to share them with the community as early as possible to get feedback.
iRhino3D WIP (8.0.23123 (11.1.1) - May 3) is now available via Testflight
Features Added:
Bugs Fixed:
  • RV-780 Restoring markups doesn’t work in Layouts
  • RV-772 Display flickering when running command
Enhancements:
  • Separate layer visibility control in model/layout space
  • RV-752 Option to collapse/expand child layers
    RV-770 Fractional lengths for scanned room dimensions in feet and inches units
WIP releases of iRhino3D via Testflight contain some features that are not completely finished. For a stable release download iRhino3D from the AppStore.
iRhino3D WIP (8.0.23154 (11.1.1) - June 6) is now available via Testflight
Features Added:
Bugs Fixed:
  • RV-816 AR free point orientation
  • RV-815 Remove Surface Detection for devices without LiDAR
Enhancements:
  • RV-813 Faster AR image tracking
  • RV-814 Make Settings persistent
  • RV-802 Make the command prompts visible by default
  • RV-801 Accesing the last run commands in iRhino
iRhino3D WIP (8.0.23220 (11.2.1) - Aug 10) is now available via Testflight
Features Added:
  • RV-831 UI for common commands
  • RV-805 Use the Rhino icons in iRhino
Bugs Fixed:
  • RV-837 Espresso Machine doesn’t have skylighting or good reflections in iOS Rhino
Enhancements:
  • RV-836 Better touch interaction for getpoint
  • RV-789 USDZ file import not paying attention to textures
iRhino3D WIP (8.0.23233 (11.2.1) - Aug 23) is now available via Testflight
Features Added:
  • RV-849 Ability to manipulate the view while drawing
  • RV-845 Repeat last tool/command
  • RV-851 Give haptic feedback when point is placed in continuous draw mode
Bugs Fixed:
  • RV-846 Keyboard covers drawing area after starting a command
Enhancements:
  • RV-844 Allow more tools to be visible at once
iRhino3D WIP (8.1.23259 (11.2.1) - Sep 18) is now available via Testflight
Features Added:
Bugs Fixed:
  • RV-701 Crash _CreateTextureFromDib
Enhancements:
  • RV-853 Distinguish primary and secondary action in tableview
iRhino3D WIP (8.1.23299 (11.2.1) - October 27) is now available via Testflight
Features Added:
Bugs Fixed:
  • Multiple display related bugs
Enhancements:
  • RV-875 Markups on new File
  • RV-885 Hide custom toolbar items in markup mode
