Essentially what I am trying to do is create in a batch, a line between two curves when the gap between them is greater than .1mm. There will be thousands of such lines created. Essentially I’m trying to keep the spacing between lines relatively consistent by adding an intermediate line when the distance exceeds X. (see yellow lines in attached)
please post those curves as actual curves instead of pixels ![]()
Thats a very small sample of what I am trying to accomplish. I guess I am more asking as to whether or not anyone has needed to accomplish the same, and has a trick or procedure to do so. Thanks in advance!
