Interior render rhino 8
When i try to make interior render with rhino 8 render without interior light, its always too dark despite i increase intensity of sun, zénithal light. Is not possible to increase exposition like with a caméra ??
You may want to use tonemapping, set to filmic with low contrast.
Hello Nathan,
Ok thanks, its work when I make render but not directly in the view with ray tracing mode
despite posterior effect is active in the raytracing mode
You need to enable also tone mapping in the render window (répartition des tonalités). Don’t change Hue, Saturation, Value post effect (turn that one off).
There is currently a bit of a disconnect between post effects in the viewport and post effects in the render window (but it is being worked on).
