is there a way to have instances from curves, surfaces or any object in rhino without the worry of breaking the history when moving or rotating or…? some instancing like what’s in Maya. I know using blocks can handle something, but blocks are not associated with history when for example we convert a curve into a block and use that curve to make a surface. the surface will be simply detached from the curve after blocking.
I use sub-curving and mirroring as the best option but that is limited. I want more freedom.
I also used grasshopper to define some offset to the curves I make, but I don’t know how to use unbaked previews with my actual curves. is there any auto bake node?
