Interactive render from non baked grasshopper geometry
Hi There,
for my MARCH Thesis I am working on an interactive installation. I have a grid which gets distorted based on visitors movement.I want to know How I can get interactive render in grasshoppers without baking geometries. so I can project that interactive render into plexiglass glass .
I already tried custom preview, but it doesn’t work with lines .
Ill appreciate it if any one can give me a help
Hi.
There are probably already better solutions in the forum… anyway:
this is a small c# script:
 private void RunScript(Guid x, GeometryBase y)
    Rhino.DocObjects.ObjectAttributes attr = new Rhino.DocObjects.ObjectAttributes();
    attr.ObjectId = x;
    RhinoDocument.Objects.Delete(x, true);
    RhinoDocument.Objects.Add(y, attr);
you will have a geometry (y) sent out to Rhino environment with a fixed GUID** (x).
It just “mindlessly” delete any previous geometry with that specific guid and “bake” a new geometry.
It doesn’t work with lists. It’s just an example.
live_bake
live_bake.gh (6.1 KB)
It should work with any geometry, but I suggest you to avoid it using surfaces/polysurfaces/breps as rhino will do the meshing every time and that will slow down the solution.
** Globally unique identifier
Thanks Ricardo, I will try that
and thanks for sharing the file
