Hi, I am running Rhino 8.10 on Windows and I’m struggling to get Block Edit New to work in that environment. It seems to work fine in the standalone environment. Has anyone had this issue before?
I’m wondering if this has anything to do with the instructions editing the Program Files but Rhino.Inside might be referring to roaming AppData??
I have the same issue, I tried the manual and automatic install method. I was actually updating the plugin from a earlier version that did work in both stand alone Rhino and Rhino Inside.
I found the solution, the developer had already a fix the developer posted.
You can replace BlockEditNew_V8.rhp in the load path with BlockEditNew.rhp from the zip package to resolve this issue.
Here are two solutions:* After closing Rhino, rename BlockEditNew.rhp to BlockEditNew_V8.rhp and replace the file in the load path
([YourUserFolder]\ AppData\ Roaming\ McNeel\ Rhinoceros\ BlockEditNew\ BlockEditNew_V8.rhp)
Alternatively, after closing Rhino, delete the BlockEditNew_V8.rhp file in this path and paste BlockEditNew.rhp. Then open Rhino and drag BlockEditNew.rhp from this path into the Rhino window.
Option A does not modify the registry, while Option B is handled by Rhino for registry loading. Choose either one.
I have a different problem than the others and I wonder if you can explain what’s going on. So installed the same plugin but everything loads fine. It’s when I try to use the plugin, particularly the command “Block Edit”. When I run Rhino 8 by itself the plugin works fine and the “Block Edit” command is listed in the commands
I’ve just released a new version, BlockEditNew 2.0. It is fully written in the .NET Framework and tested on the .NET Core platform. Also, Rhino 8.20+ has made some adjustments that fix the installation issue, so it will have better compatibility with my plugin. Now you can install through Package Manager.
Welcome to download and test it. For any questions, please contact me at: wucl12@foxmail.com
When i used the package manager to uninstall it worked ok.. but when I then re-loaded rhino (without the plugin) double clicking to edit a block was disabled.
The error message was something like DblClkBlock_Command not known or something (sorry have now resolved and can’t remember exact wording– but it looked as if when double clicking a block it was summoning a further command which no longer existed
This is a known bug on the Rhino side. Please update to the latest version of Rhino 8 to resolve it. Alternatively, manually deleting the BlockEditNew.rhp plugin file and restarting Rhino may also help.
