In Rhino inside Revit WIP 2025, when I edit a block with blockedit, the dialogue box does not popup, So I cannot exit the editing. The only solution I found is to save the file, open it in a Rhino instance outside of Revit, close the editing (since with “Rhino outside Revit” the dialogue box does pop up), resave and open it in RIR.
Hi Roberto, I’m sending you a daily build. Testing this and the existing UI issue (move layer panel size) is working as expecting for me. Thanks
