Hi, has anyone ever had a problem with currently installed printers (particularly Adobe PDF, or PDF995) suddenly disappearing as options in the print destination? They’re gone from Rhino7 but they’re both still available in my Rhino6.
Hi Vince -
I don’t recall running into this. FWIW, the recommendation is to use the RhinoPDF printer to create PDF files from within Rhino.
Thanks for the reply Wim, I never figured out what caused the issue, but managed to find a solution. I did an options export from Rhino6 and imported it into 7 and it did the trick. Now all my print destinations are available.
