Hi…,
this customer complains here, that he can’t select printers (instead pdf) since the last Rhino 6.5 upgrade:
https://www.flexicad.com/service/forum/index.php/topic,8800.0.html
Any ideas?
Thanks
Michael
www.flexiCAD.com
Hi…,
Any ideas?
Thanks
Michael
www.flexiCAD.com
It sounds a bit like this one:
A fix for this is in the works. You can track the progress here.
Hi Wim and Tim,
thank you very much.
Michael
P.S. FYI: Tim, the tracking link is not public.
Hi Michael,
There is some user data in the YT item and, as such, it is set to be visible to the developers only. When the issue is resolved, Brian will add a post to this thread…
Hi Wim,
I wondered in the past, why some youtrack topics are protected. Now I know.
Thank you very much and have a sunny weekend
Michael
Hi Michael,
You should be able to see the YouTrack issue now. It was actually an oversight on my part. I had set public view to allowed but had not unchecked the visibility (from developers only).
Wim is right though, when there is a file or something else of proprietary value we limit the visibility in part or whole. In this case it was just an image. There is a link to our internal support channel but you need proper credentials to follow that link so I think it’s ok. I’m sure someone here will give me a good reprimand if they disagree.
Cheers,
Tim
Hi Tim,
yes, I see it know, and thank you for all the details.
Cheers
Michael
