The file did not open when I started installing it, how can I fix this problem
I assume this is a plugin?
If so please contact the developer of this plugin directly for install help-
Hi Ahmend- please run the SystemInfo
command in Rhino and copy/paste the resaults here.
You may need to associate - or re-associate - rhi files using
http://files.mcneel.com/rhino/6.0/RhiFix.exe
Hi Ahmed - without the results from Rhino’s SystemInfo
command, it is diffuicult to know what to do.
How I can get it ( Rhino’s SystemInfo
command )
Ahmed
Hi Ahmed -
Which version of Rhino are you running?
RhinoCFD_2.1.5_for_Rhino7
Hi Ahmed - please open Rhino and type SystemInfo
at the command line and then copy and paste the entire output here.
Hi Ahmed,
Excuse me if I am misunderstanding, but I get the impression that you expect RhinoCFD to install Rhino and you don’t have a prior copy of Rhino installed. RhinoCFD is an addon (or plugin) for Rhino. It doesn’t include Rhino, so you need to have a copy of Rhino 7 installed first.
HTH
Jeremy
