Install Devsrf not working
I downloaded the Rhino5 64 bit version of DevSrf, and after extraction, copied it into the Rhino\Plugin Folder.
However, when I type DevSrf into the command line, it doesnt “see” DevSrf" in the dropdown list as an option.
Is there a special trick to this ?
Thanks
Tools > Options > Plug-ins.
Make sure the plug-in is there, and marked loaded. If not drag the .rhp file on top of your running rhino 5 64bit version.
Thanks for the Reply. I looked up Help in Plug-Ins, and it is very incomplete. It doesn’t say “Tools->Options->PlugIns”, just "Right Click in The list area. I tried to figure out what a “list area” is, but there is no topic in Help called “List Area”
I used the “drag” onto the 64 bit program, and that worked.
Many thanks for the assistance.
Glad the drag&drop worked for you
