Inset command Rhino8
The new inset command for Rhino8 can ignore seams, but not tangent edges.
If you make a cube, with a big fillet and run the inset command and select select the fillet surface as well as the surface in the top and bottom of the fillet, then the inset command only makes individual insets for each surface, not all faces as expectet.
I guess the programmer forgot this situation during development.
Regards
Leif Rosenbæk
Hi Lief - indeed that is not supported at least not yet,
RH-78146 Inset: Ignore tangent edges
RH-72296 is fixed in Rhino WIP
