Insert Edge> SubD > Rhino 7
I am trying to locate the insert edge command in sub-D. After selecting the edge ring, I want a horizontal edge using the insert edge. However, it does not work
You may need InsertPoint or select the perpendicular edgeloop to the edge ring and use InsertEdge on that instead.
