Inquiry Regarding Custom Keyboard Shortcuts for Level Navigation
Hi guys!
I would like to inquire whether it is currently possible to assign custom keyboard shortcuts (aliases) to facilitate navigation between levels within the application. Specifically, I am interested in the possibility of assigning a key combination, such as Ctrl + Up and Ctrl + Down, to move up or down a level respectively.
Such functionality would significantly improve workflow efficiency, especially in projects involving frequent level transitions. If this feature is not yet available, I would kindly suggest it as a potential enhancement for future updates.
Thank you in advance for your support. I look forward to your feedback.
Alessandro
Hi @Alessandro_Barbisan you can already navigate inside the Level Manager with the Up and Down arrows (just like you can do it in other panels, like the Rhino Layer panel). But of course, you need to click inside the panel first.
Which other actions would you like to do via commands or key shorcuts?
@fsalla Maybe I didn’t explain myself clearly. Right now, when I’m in the top view and I press the up/down or left/right arrow keys, the view just pans up/down or left/right, it doesn’t move to another level.
It would be great to have a shortcut that lets me go to the level above or below when I’m in the top view.
Does that make more sense now?
Hi @Alessandro_Barbisan I understand. But I’m afraid this is not possible. To do so, you should be able to “jump” from the Rhino Viewport to the Level Manager to navigate through the levels, and this is something that doesn’t work right now. Using the Tab key you might be able to jump from the different panels and dialogs, but Rhino doesn’t let you do so. Once you get to the Command line, you cannot quit that dialog with the Tab key. This is something controlled by Rhino, which we can’t help.
