i am trying to simulate an inflated fabric cover using K2.
i am not able to “stitch” all different piece of fabric…i tought that coincident points = stitched point but for some reason that i don’t know some of the stitching lines are not connected and panels are coming apart when subjected to pressure.
many thanks !!! , they seemed to be coincident to me but eventually they weren’t you are right ,
i have also tried the MagnetSnap goal and adjusted the goals strenght and it seems to be more realistic., i think it means that points are close enough to be recognized as concident..doens’t it ?
can i ask you a further question ? I would like to add diagonals lines and add them to lenght goal in K2 to better simulate fabric behavior, i tried to deconstruct mesh and extracr faces corners but i am not able to get it to work.
would you take a look to attached definition and see what is wrong? thanks
thanks @martinsiegrist , it took me a while to get it to “work” but i still struggle to have a realistic behavior.
at first I tried to feed all lines ( edges+diagonals ) in to the same lenght goal ( same strenght ) but diag lines were still streching , especially in the corners.
i then tried to use 2 lenght goal with different strenght on diagonal in the hope to reduce stretch at corners but things got worse.
i tried to connect naked edges to same lenght goal as diagonals..those have strenght 2 orders of magnitude the panels edges..i still think the behavior is not realistic at all.
well , i am not going to make this , the trial was just meant to simulate real ripstop fabric ( at least under a looking point of view) the same i use for kites , to arrange to strut was easier that making a kite or a sail model for istance.
in reality the bias properties are not 2 order of magnitude the warp weft properties ( the real behavior is actually the opposite ) ..i.e. it is correct to have alongation bias wise but not as much as we see in these examples
