File Units - mm
Mesh is a perfect quad remeshed mesh with 1900 quad count (approx)
the mesh is not sticking to the edges whereas with the same force settings, the mesh is perfectly able to anchor to the mesh corners when processed
Please help TvT
The result I’m getting
Desired Result
Script
I can’t say for sure without the file, but I’m guessing this is a tolerance issue.
The value in the Kangaroo Tolerance input is the distance below which points get joined into a single particle. This should be bigger than any numerical imprecision in the input model, but well below the length of the shortest mesh edge.
thanks man, it worked after setting it to 0.1
