Inflatable pillow with sticked triangle
Hi guys
I’m trying to create a module in grasshopper for my peoject and need some help.
I’m iron a plastic bag with triangle and inflate it to recieve a different shape.
This goes like this:
-create a close square from two surface of plastic bag (creating a pillow).
-Fold the pillow into 2 and iron a triangle with a different angle, like this:
-Inflate the pillow, and then I get something like this:
I found out in other post how to create a pillow with a hole inside and inflate it.
But when I try to change the to something like diamond- it all goes wrong.
I thought this shape can help…
In conclusion I can’t figure out how to create the fold and iron a triangle with a different angle.
any idea?
inflate_bend.gh (52.0 KB)
For your file you had many different surfaces instead of a single mesh. Here’s a fix for that:
inflate_bend.gh (50.4 KB)
It’s not clear to me how your definition relates to your image above though.
In your top right image is that supposed to be already a bag (2 layers of plastic sealed around the edge), so when folded in the middle image there are 4 layers of plastic?
Then which layers of plastic are being ironed together?
@DanielPiker
Thank you for your respond.
The top image refers it’s a close bag (like not inflated pillow - with 2 layers) and when folded - in the middle there are 4 layers of the plastic.
All the 4 layers are iron toghther and then I inflate the pillow.
Is that answering your questions?
So something like this?
inflate_weld.gh (14.1 KB)
:scream_cat:
YES
I’m having trouble to open the file -
I’m using rhino6.
What should I connect between the ‘join’ component and ‘C#’. How to create the input mesh?
Ah, any possibility to update to R7?
It’s a new meshing tool that makes this process a lot easier.
inflate_weldR6.gh (26.3 KB)
Here’s a version that should also work in R6.
The R7 one will be a bit more reliable though.
