In the documentation, it says
If true, it means the command has been run with a ‘-’, meaning you should not ask questions during writing. (no dialogs, no “getters”, etc.)
However, if you pass an option with SuppressDialogBoxes
as true
to any exporter that uses RhinoObject.MeshObjects
, e.g. Rhino.FileIO.FileObj
. Such getter will still appear in the command window, wait for user input and block the batch procedure:
Choose meshing option ( DetailedOptions PolygonDensity=50 )
I’m unsure whether the behavior is intended but it seems not.
