this is my code for exporting a number of objects, each to its own file:
bool isSolid = true;
List<Rhino.Geometry.Brep> breps = new List<Rhino.Geometry.Brep>();
const Rhino.DocObjects.ObjectType geometryFilter = Rhino.DocObjects.ObjectType.PolysrfFilter | Rhino.DocObjects.ObjectType.Mesh | Rhino.DocObjects.ObjectType.Surface;
List<Rhino.DocObjects.ObjRef> objrefs = new List<Rhino.DocObjects.ObjRef>();
Rhino.Input.Custom.GetObject go = new Rhino.Input.Custom.GetObject();
go.SetCommandPrompt("Select surfaces, polysurfaces, subDs or meshes to export");
go.GeometryFilter = geometryFilter;
go.GroupSelect = true;
go.SubObjectSelect = false;
go.DeselectAllBeforePostSelect = true;
Rhino.Input.GetResult res = go.GetMultiple(1, 0);
if (res == GetResult.Cancel) return Result.Failure;
if (res == Rhino.Input.GetResult.Object)
for (int i = 0; i < go.ObjectCount; i++)
Rhino.DocObjects.ObjRef objref = go.Object(i);
objrefs.Add(objref);
if(objref.Brep() != null)
if (!objref.Brep().IsSolid) isSolid = false;
else if (objref.Mesh() != null)
if (!objref.Mesh().IsSolid) isSolid = false;
else if (objref.SubD() != null)
if (!objref.SubD().IsSolid) isSolid = false;
else if (objref.Surface() != null)
if (!objref.Surface().IsSolid) isSolid = false;
else
return Rhino.Commands.Result.Cancel;
else if (res != Rhino.Input.GetResult.Object)
if (!isSolid)
Dialogs.ShowMessage("At least on object is not solid! Export might not be valid!", "Warning!");
var ofd = new Eto.Forms.SaveFileDialog
Title = "Export",
Filters =
new Eto.Forms.FileFilter
Name = "STEP (stp,step)",
Extensions = new[] { "*.stp" }
Name = "STL (stl)",
Extensions = new[] { "*.stl" }
Name = "Rhino3dm (3dm)",
Extensions = new[] { "*.3dm" }
CurrentFilterIndex = 0
var result = ofd.ShowDialog(RhinoEtoApp.MainWindow);
if (result != Eto.Forms.DialogResult.Ok)
return Result.Cancel;
String path = ofd.FileName;
String[] splipath = path.Split('.');
doc.Objects.UnselectAll();
Rhino.UI.ShowMessageResult fileRes;
for (int i = 0; i < objrefs.Count; i++)
Rhino.DocObjects.RhinoObject ro = objrefs[i].Object();
ro.Select(true);
var filename = splipath[0] + "_00"+ (i+1) + "." + splipath[1];
if (System.IO.File.Exists(filename))
fileRes = Dialogs.ShowMessage("Filename already exist! Overwrite existing file?", "Warning!", ShowMessageButton.OKCancel, ShowMessageIcon.Warning);
if (fileRes == ShowMessageResult.Cancel)
continue;
doc.ExportSelected(filename);
ro.Select(false);
return Result.Success;
When the code opens the ofd.ShowDialog(RhinoEtoApp.MainWindow); dialog i can choose from the list of file formats but it keeps the initial file extension after the file name.
Is there an option that i am missing?
