Inconsistent save times
Hi all,
Building a small, simple model for some PC parts, and the file is acting odd on saving. The file stays around 5-15mb in size. Sometimes it saves instantly, as expected as i’m running my system on an nvme ssd. Other times it takes 10 seconds (I know,10 seconds, such a long time to wait… /s).
But seriously, what could be causing it such dramatic differences in save time? I noticed it takes a little bit longer to save when I first start Rhino and do some modelling or drawing. Then it tends to even out and save instantly after a couple minutes.
Found this thread and turned off the setting, issue persists.
Also this thread didn’t solve it.
Relevant system/file info below:
Audit3dm:
audit3dm_results.txt (87.4 KB)
SystemInfo:
Rhino 7 SR14 2022-1-10 (Rhino 7, 7.14.22010.17001, Git hash:master @ d8a2d020be8cb487bfc091316ef32170cfc7eddb)
License type: Educational Lab License, build 2022-01-10
Windows 10.0.19045 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3090 (NVidia) Memory: 24GB, Driver date: 7-12-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.67
- Secondary monitor attached to adapter port 0
- Windows Main Display attached to adapter port 1
Secondary graphics devices.
Intel(R) UHD Graphics 770 (Intel) Memory: 1GB, Driver date: 2-3-2022 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-12-2023
Driver Version: 31.0.15.3667
Z-Buffer depth: 24 bits
Total Video Memory: 24 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\BenjaminTH\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.14.22010.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.14.22010.17001
Hello - two things - one, please update Rhino to the current service release, which is sr 31
https://www.rhino3d.com/download/rhino-for-windows/7/latest
and, also please disable the two plug-ins above in Options > Plugins page, then close and restart Rhino and see if the behqavior persists.
Thank you Pascal. Vray seems to be the culprit. Disabling it solved the issue.
Is there an alternative where I can keep Vray enabled?
Hi -
You might want to report that to Chaos Group.
I’m not aware of any workarounds for this one.
