I have imported a custom toolbar from RH8 to RH9 , i made it by copying the RUI file for this customized toolbar from the RH8 folder to the the corresponding RH9 folder
the toolbar showed up but i cannot edit it since the edit button is not active + if i preselect the object and click on some of the icon the macros does not feel the preselected object.
I launched OptionMigrate command , i selected the Rhino version (8) to import options from but beside not solving above mentioned problem ( unable to edit the toolbar macros ) it also changed the software language to one i never used ( it’s always been English , it switched to Italian ).
Hi @CallumSykes , thanks for your suggestion , i dont know i got you right but i realized that if click RMB over the toolbar icons the editor opens and i can edit the macro/script , which is even faster that pressing edit.
