Importing paid for assets re allocating materials
Hello - i buy a lot of assets from Turbo Squid etc and most were able to be imported into sketchup ive tried both FBX and OBJ but almost always they come in without any materials - even if i ensure the .mtl is in the same folder - any tips or workarounds?
Hi @Thomas_Boundary ,
The mtl file references object, material and texture names but the texture maps themselves will also need to be in the same directory as the obj and mtl. Maybe that’s the issue? Or the obj/fbx download was missing the textures? You mention importing into SU but if you have the same issue in Rhino it’s likely for the same reasons.
You can open the mtl files and see what sort of path is used for the image files. Make sure they match what you have on disk
That too, but if they are in the same directory to begin with, Rhino should find them.
