I am experiencing an issue when I am importing a complex assembly file (exported from Pro-E or Solidworks)
It comes with a lot of strange curves (lines) and some surfaces that do not belong to the original 3D model.
I have to explode a lot of blocks and objects in order to delete the unwanted curves. But I am not able to get rid of the strange surfaces that are somehow connected to an original surface.
Any idea how I should deal with this in a more simple way?
Without seeing the actual geometry it is difficult to say what might be wrong.
Maybe someone else will chime in with experience importing STPâs with these symptoms and a possible solution.
I strongly advice you to either post the STP file and resulting import here, or you can also Upload these files
to McNeel: http://www.rhino3d.com/upload
Note that these file will be treated with integrity. However uploading here or to McNeel offers 2 advantages:
1: You might get a fast and to the point solution
2: It allows McNeel to improve their importer and or fix bugs; in turn improving Rhino itself.
You might want to isolate the problematic surfaces and save only those in a file, to reduce the filesizes.
Edit: You can also try and open the Solid Works file directly in Rhino (end of edit)
Hi, this can happen with both STEP and IGES files.
What happens (and I donât know why) is that these errors are due to trimmed surfaces where the trimming has gone bad, so either the wrong part has been removed, or they have not been trimmed at all.
First thing you can do is to try and open it in Rhino 4. It might help.
Or try and export with a slightly different setting if possible.
Regarding STEP and naked edges I have addressed the following on a few occasions: There is no tolerance overriding option in Rhino, and Solid Works tend to export the STEP at a higher tolerance than the original SW file, and Rhino 5 was altered so it is nit-picking at these numbers, resulting in errors that Rhino 4 would ignore. So these are actual SW errors that Rhino used to âacceptâ, but donât any more. Rhino is ârightâ, but it is a problem for the user.
Hopefully we will get a tolerance overriding option for V6.
Hi Wikit- please send us one of these files if you can- tech@mcneel.com, Attân Pascal, The smallest/simplest file that shows the problem would be the most useful. As for the extra curves, my guess is this is controlled at the export end of things, i.e. in ProE or SW - from Rhinoâs perspective, if the data are in the file, weâll try to read them in. But, send a file, if you can, and weâll take a look.
Thank you all for your advise.
Unfortuntately I am not able to share the confidential file or image.
I will meet the engineer soon who sent me the file, and will ask how he export the things from his end.
Perhaps those are curves that he used to to make the 3D modelâŚ
The way I solved this now, is to explode the blocks into objects until I can select the unwanted curves separately and delete them.
Strange curves appear, because the model was exported together with the construction lines that were used in pro-e
Strange surfaces appear, because the model was exported with other âsurfaceâ options selected. The only option that should be selected is âsolidâ when exporting
For the blocks, i have to explode them until objects are created in Rhino
